MHI operates pressurized SOFC-MGT hybrid system for an uninterrupted 4,000 hours
Mitsubishi Heavy Industries, Ltd. has achieved 4,000 hours of uninterrupted operation of a 200 kW class pressurized hybrid (combined-cycle) power generation system incorporating solid oxide fuel cells (SOFC) and a micro gas turbine (MGT). The company has been operating the hybrid system since March at Senju Techno Station, a facility in Tokyo operated by Tokyo Gas Co. Ltd., and it has now confirmed its stable power generation performance: generating-end output of 206 kW AC (alternating current) and 50.2 percent thermal efficiency.
MHI began developing the pressurized hybrid power generation system in 2008 at its Nagasaki Shipyard & Machinery Works, working in collaboration with the New Energy and Industrial Technology Development Organization (NEDO). The first stage of power generation takes place in the SOFC module by injecting city gas as fuel to produce electricity through chemical reaction. SOFCs are ceramic-based fuel cells that operate at a high temperature above 900 degrees Celsius (1,650 degrees Fahrenheit) and produce electricity directly by chemical reaction between hydrogen and carbon oxide removed from city gas and oxygen in the air.
The unreacted portion of the gas and hot air discharged from the SOFC module are then used to drive an MGT. This two-stage system achieves significantly higher power generation efficiency and, as a result, saves substantial energy. In addition, as the high-temperature exhaust gas from the MGT can be used to generate hot water and steam, the hybrid system is capable of performing combined heat and power (CHP) supply functions.
In the pressurized hybrid system, air pressurized by the MGT's compressor is supplied to SOFCs and used as oxidant; then the thermal energy and pressure of the high-temperature exhaust gas from the SOFC module are transferred to the MGT to be used, together with the unreacted portion of the gas, to produce electricity.
In this system, the inherent ability of pressurized SOFCs to increase voltage significantly is effectively utilized to enhance power generation efficiency. The system has also reduced installation space requirements by half, by boosting power density through enhanced SOFC module performance and a simplified system configuration.
Tokyo Gas' Senju Techno Station, where the pressurized hybrid system was installed, also contains a facility where the utility introduces its advanced energy-related technologies to its stakeholders. The station agreed to cooperate with MHI in its continuous operating test in consideration of its function as a supplier of city gas -the fuel used in the hybrid system. The testing demonstrated stable operation even in the heavy-load summer season.
