NEW PRODUCTS & SERVICES
Coupling turbine trains
The Rotalign Ultra MultiCoupling feature allows the alignment of up to seven machines in a train to be measured simultaneously, with a single quarter rotation (or less) of the shafts. This saves time and resources when aligning turbine trains on the critical path in an outage, or machine trains with gearboxes that are difficult to turn.
www.ludeca.com
Turbine lowers NOx
Kawasaki Gas Turbines-Americas announced the world's first commercial operation of a new low emissions technology from Kawasaki and Catalytica Energy Systems, Inc., which has been retrofitted at a gas turbine co-generation facility at the Sonoma Developmental Center in Eldridge, CA. The core of the system is a 1.4 megawatt Kawasaki M1A-13D that has been rebuilt to accommodate the new Xonon Cool Combustion system from Catalytica, which employs a catalytic combustor that achieves less than three parts per million of NOx.
www.kawasakigasturbines.com
Digital flow computer
Krohne, Inc has released the Summit 8800 Digital Flow Computer, which features a touch screen graphic display, as well as performance, handling, and interoperability improvements over standard flow computers. It can used in metering oil, gas, wet gas, steam and water; bulk chemicals batching; heat exchanger metering and logging; and metering production processes.
www.krohne.com
Heat-of-compression dryers
Ingersoll Rand has announced a line of heat-of-compression (HOC) dryers. The dryers turn wasted heat into useful energy, resulting in clean, dry, oil-free air at a fraction of the cost of traditional desiccant dryers. By using heat produced during the compression process, Ingersoll Rand HOC dryers can deliver instrument-quality air using approximately the same energy as a 150 watt light bulb.
www.ingersollrandproducts.com
Ultra cool bearings
Voith Ultra Cool Bearings have a heat conductivity six times higher than that of other materials. Cooling channels ensure faster heat conduction by reducing the heating of the oil that comes into contact with the bearing surface. The Ultra Cool Bearings are offset journal bearings. The interior shape of two offset half-shells affix the shaft, particularly at light-duty or idling speed.
www.voithturbo.com
Carbon-graphite pump parts
Metallized Carbon Corp. announced the availability of custom vanes, rotors, and end plates for use in rotary vane pumps used in pumping liquids and gases. The carbon-graphite components are well suited to pumping liquids with poor lubricating qualities, strong chemicals that attack metals, and to pump air, vacuum, combustion products and gasoline vapors.
www.ipsenusa.com
Sprayable ceramic coating
Henkel has introduced a two-part, sprayable ceramic coating designed to protect metal surfaces on industrial equipment from wear, abrasion and corrosion. Packaged in a reusable dual-cartridge dispenser, Loctite Nordbak 7255 Sprayable Ceramic Coating is sprayed onto metal components to create low-friction surfaces that improve equipment efficiency. The coating can be used on tank linings,mixing vessels, pump housings, impellers, chutes, troughs and centrifuge components.
www.henkelna.com
Machining energy parts
Mag’s modular HMC 1250/1600 Series is engineered for high-precision machining of aerospace, power generation, pump, valve, and off-road equipment The high-torque spindle is suited for hard-metal cutting, while the live spindles extendW-axis reach by up to 800 mm (31.5 in), enabling deep cavitymilling to high precisionwith shorter, more rigid tools.
www.mag-ias.com
Corrosion resistant LED
Magnalight.com announced the addition of an explosion proof LED light with non-metallic housing for applications where high resistance to corrosive environments is needed. The HAL-CRNMLED7W LED light fixture features the combination of a high output LED lamp to provide more light than 100 watt incandescent lamps.
www.magnalight.com
Easier field inspections
The Iplex Ultralite is a palm-sized videoscope that can facilitate field inspections in areas with limited access or cramped space. With its durable body and crushresistant insertion tube the Ultralite weighs only 1.5 lb (700 g). The ergonomic instrument, with its lithium battery, fits snugly into the palm of your hand and comes with a range of interchangeable optical tip adapters. And the bright LED mounted on the tip adapters clearly illuminates targets. The scope tip instantly responds to the articulation control and approaches targets precisely, enabling fast, efficient inspections. Observed images can be stored in a connected SD or SDHC card as high-quality JPEG still images and MPEG-4 movies.
www.olympus-ims.com
Ingersoll Rand controls
Ingersoll Rand has released Xe-Series Rotary Compressor Controls for the R90- 160ne Nirvana VSD Premium Efficiency and the R90-160n Nirvana VSD Efficiency rotary screw air compressors to optimize plant efficiency. The Xe-Series control is a more convenient and reliable monitoring system that provides a window into all vital compressor data. The Xe-Series controller debuted last year on the Ingersoll Rand R55-75ne Nirvana VSD Premium Efficiency and R55-75n Nirvana VSD Efficiency rotary screw air compressors and is now available on the larger systems.
© 2024 MJH Life Sciences
