Parker Hannifin, a motion and control technology company, launched a new line of filters for high-performance gas turbines, called “clearcurrent ASSURE” filters.
Clearcurrent ASSURE Cartridge
Parker’s new filters feature durable hydrophobic and oleophobic properties, which remove problematic contaminants carried through to the turbine in liquid forms. Their design provides effective filtration across a range of models including high-performance self-cleaning units. Construction practices and materials are selected for extended service life to enable longer maintenance intervals and reduced lifetime cost while sustaining performance.
The measured and consistent performance of the clearcurrent ASSURE filters through all filtration stages equates to predictable differential pressure (DP). This is essential to avoid sudden pressure spikes that lead to unplanned turbine outage or damage to the system. They are designed to an exact fit in the inlet house to prevent them being bypassed, significantly reducing the risk of accelerated degradation of turbine components and helping to optimize maintenance over the life of the system.
All components within the latest advanced gas turbines must be able to withstand the harsh environments and multiple contaminates that these systems are continuously exposed to.
Filtration systems for gas turbines require consistent innovation to keep pace with ongoing improvements to turbine design and performance. Advanced classes of turbines have recently broken the 60% net efficiency barrier in combined cycle mode. By leveraging technologies such as 3D printing and advanced analytics, such increased levels of efficiency are becoming increasingly common, and it is expected that further improvements will soon follow.
“The efficiency we see from today’s advanced gas turbines, such as the H-class, is far superior to that of previous machines,” said Tim Nicholas, power generation market manager, Gas Turbine Filtration Division. “The precise engineering involved to achieve these output levels requires a conditioned, consistent and reliable air flow through the inlet house, and our new line of filters helps to protect turbine health and performance.”
“The lower efficiency of legacy turbines means that particles adhering to the blades have less impact on performance. However, to maintain the efficiency of the advanced performance turbines entering the market today, internal components need better protection from sticky particles in the inlet airflow which can impact aerodynamic and thermal performance,” Nicholas added. “Our clearcurrent ASSURE filters are designed with housing materials and filtration media that is precision-engineered to set a new benchmark in protecting these incredible machines.”
