technotrans New Oil Control Unit
teco ct 130 base 60 has up to 130°C and a heating capacity of 6 kW
The technotrans teco series, on the far left: the teco ct 130. technotrans.
The teco ct 130 base 60 from technotrans is now available. The oil control unit maintains temperature to increase overall efficiency. The base.line variant of the teco ct 130 is suitable for a temperature range up to 130°C with a recirculation rate of up to 60 l/min. The unit has a heating capacity of 6 kW. Lossless heat transfer is enabled by an integrated stainless steel heating cartridge. Moreover, multi-voltage variants from 400 V to 460 V as well as dual-frequency versions for use in 50 Hz and 60 Hz networks are also available. A large heat exchanger surface provides a cooling capacity of up to 30 kW. In addition, the company offers customized oil-based solutions for temperatures up to 400°C and a heating capacity up to 750 kW. technotrans.com
