TurboTime Podcast: Factory and Field Testing with the Myth Busters
In this episode of the TurboTime podcast, Klaus Brun and Rainer Kurz discuss turbomachinery factory and field testing—what they are good for, cost, and more.
Myth Busters Klaus Brun and Rainer Kurz join the TurboTime podcast to talk about turbomachinery factory and field testing—why are turbomachines tested, what’s standard, what’s extra, are the costs really worth it, uncertainty versus accuracy testing, different types of compressor-performance tests, how to test a gas and a steam turbine, and when is a full-string test necessary?
Brun explained: “When you make a machine of any kind, before delivering it to a customer, you want to make sure it actually functions, so standard tests are performed and then there are additional tests that some customers may require. Complex turbomachines—compressors, gas turbines, steam turbines, and even pumps—require some kind of factory testing to make sure the machine meets the basic functionality, it doesn't fly apart, and it performs at a certain level. From there, it gets a little more complicated, as each machine is different. For example, a gas turbine performance test can be performed in the factory or the field. In the factory, a prescribed test by API 616 could be used.
“A field test is a fundamentally different test where the machine is already installed, commissioned, started up, and sent to some engineers or technicians in the field to test under the conditions that may not necessarily be identical to the conditions that the machine was originally designed for or contractually agreed to or under factory testing conditions, so it's a more challenging test.”
