Anti-corrosion metal coatings
5000 hours of corrosion protection in salt spray testing for metals
The Greenkote G5k coating delivers a minimum of 5000 hours of corrosion protection in salt spray testing for metals, enabling it to meet ASTM Specification B117. It also eliminates the introduction of hydrogen embrittlement, which is an intrinsic problem with many traditional anti-corrosion coatings. The coating process doesn't use any hazardous chemicals or produce any toxic byproducts, and can replace anti-corrosion processes such as electroplating, hot-dip, sherardizing, and metal flake. These coatings can be applied to a broad range of metal parts, from threaded fasteners to stamped and cast pieces, in sizes from 0.2 to 78 inches.
This level of performance is aimed at the most challenging anti-corrosion applications, including those in marine and coastal environments as well as many automotive and industrial uses that expose metal parts to wetness or harsh chemicals for long periods of time,” said Greenkote CEO, Mark Gore.
