Camfil releases new CamClose air filter
The CamClose is a panel air filter designed to extend the service life of the final filter.
Image courtesy Camfil Power Systems.
Camfil Power Systems has released its new generation CamClose product. The CamClose is a panel air filter, designed to extend the service life of the final filter. Adding the CamClose pre-filter in front of a final filter further improves overall filtration efficiency.
New Features:
  • Patented built-in pressure drop port helps to accurately monitor filter pressure drop across each filter stage separately, enabling the operator to better plan for filter replacement.
  • Strong built-in plastic clips allow for an easy close-coupling to the final filter, without any additional hardware.
  • High burst strength > 6250 Pa (25” w.g.) and robust frame maintains filter integrity in challenging environments
  • Lowest pressure drop in the G4 panel filter class
  • Optimal and proper sealing gives best-in-class water and contaminant handling, as well as a low and stable pressure drop
  • Advanced media offers low pressure drop, long life and good water handling
  • Non-charged, high mechanical efficiency ensures gas turbine filters maintain their efficiency class in high velocity applications.
  • The new generation includes three efficiency classes and have been tested to the latest industry standards per EN779:2012 and ISO 16890: 2016.
  1. G4 / ISO ePM Coarse 60%
  2. M5 / ISO ePM10 65%
  3. M6 / ISO ePM2.5 50%
www.Camfil.com/CamClose
