Corrosion Protection
Cortec’s newest lubricant additive offers advanced corrosion protection and compatibility for ashless oil systems. This is valuable for gearboxes, turbines, and other lubricant systems at risk for corrosion from trapped water or moisture condensation. Corrosion can mean downtime and ultimate failure on these critical components. Cortec M-535 counters these setbacks with two features for corrosion protection in ashless systems.
The first is its vapor-phase action while the second feature of M-535 is its ashless chemistry. Compatibility with the base-oil is a must for additives. M-535 was designed with the needs of ashless oils in mind and a heightened understanding of ashless performance requirements. It has been formulated for use in turbines, as well as many general lubrication systems where ashless chemistry is not mandatory.
