Integrally Geared Compressors
Integrally geared compressors run at the heart of vital applications extending from LNG vessels on the high seas to complex compression requirements in petrochemical plants. Our machines are at home in air separation plants, at power facilities, in applications across the entire LNG value chain as well as in numerous related downstream processes.
Atlas Copco Gas and Process has been designing and manufacturing integrally-geared turbocompressors for over 40 years. Atlas Copco Gas and Process helps you handle the pressure with a broad range of centrifugal turbocompressors, turboexpanders, and screw compressors.
From fast-commission, standardized machines to fully custom-engineered equipment, we can engineer a solution for your most demanding process needs.
