|Articles|October 12, 2021
Metrix launches new smart signal conditioner and switch
Author(s)TMI Staff & Contributors
The 5580 and the SW5580 are a lower cost alternative to rack mounted monitors.
Metrix has announced the release of their new 5580 smart signal conditioner and the SW5580 dual channel configuration switch. Below are some product highlights:
- The 5580 and the SW5580 are a great lower cost alternative to rack mounted monitors.
- Available in a single or dual channel enabled configuration. The SW5580 is similar to the 5580 but includes optional dry or solid-state relay contacts.
- Can accept signals from machine casing mounted velocity sensors, accelerometers or shaft observing proximity probe systems, and produce a 4-20 mA output proportional to the measured variable and an amplified raw signal.
- Provides a configurable signal input type for one or two independent channels, plus the ability to scale output either to peak or RMS units, and an LED indicates alarm levels.
- The product can operate in a Dual Path Mode, one sensor in, two channels out.
- The product has Rod Drop and Impact functionality.
- Device can be configured in the field to meet application requirements using our free configuration software.
Material Matters: Engineering Polymer Components to Extend Pump MTBR
Entergy, MHI Group MOU Targets 50% CCS Cost Reduction with Integrated GTCC Solution
The Gigawatt Era: How AI’s Insatiable Appetite for Power Is Reshaping the Turbomachinery Industry
4
Howden to Supply Steam Turbines for Terra Innovatum’s Micro-Modular Reactor Platform
5
![[Howden Frankenthal TWIN turbine] | Image Credit: Howden](https://cdn.sanity.io/images/0vv8moc6/turbomag/5f5d831124199c4b7fe24bde4cfd27587653d3e7-1100x895.jpg?w=350&fit=crop&auto=format)
