Siemens steam turbines to serve Jordanian project
Siemens will supply the key components for the Attarat steam power plant in Jordan. The customer China Energy Engineering Group Guangdong Power Engineering Co. Ltd. will be the contractor and operator. Siemens’ scope of supply comprises two SST5-5000 steam turbines, two air-cooled SGen5-1200A generators, and the turbine control system. The condenser is air cooled to address the lack of water at the site. This can be seen as a global trend for dry areas where water is mainly used for households.
Siemens’ scope of supply comprises two SST5-5000 steam turbines, two air-cooled SGen5-1200A generators, and the turbine control system. The condenser is air cooled to address the lack of water at the site. This can be seen as a global trend for dry areas where water is mainly used for households, farming and ecosystem. The power plant will start operation in mid-2020 and will feed up to 470 MW to Jordan’s power grid.
The Attarat facility will supply enough electricity to cover up to 15% of the country’s annual power demand. Jordan is one of the most water-scarce countries in the world. The air cooled condensers will save up to 90% of the water needed for the plant’s operation compared with the use of a wet cooling system. Siemens will supply low-pressure turbines, which are able to withstand the high back pressure caused by the condensers.
