Elliott to supply 22 compression trains for Chinese petrochemical complex
Elliott Group has been awarded a contract to supply compression equipment for Hengli Petrochemical Refinery’s integrated refining and petrochemical complex now under construction in Dalian, China. The new refinery, the largest such project approved to date in China, is part of the Chinese government’s 13th five-year plan of social and economic development initiatives.
The order encompasses 22 compression trains and 28 casings for 14 different services including pressure swing adsorption, continuous catalyst regeneration (CCR), naptha hydrotreating, aromatics, propane/isobutane dehydrogenation, coal to H2, and sulfuric acid alkylation. The units will be built at Elliott’s manufacturing facilities in Sodegaura, Chiba, Japan and Jeannette, Pennsylvania, USA.
“Elliott’s ability to demonstrate technical expertise across various applications, including refrigeration, was key to meeting the customer’s needs for this important project,” said John Rann, Vice President of Engineered Products.
When it comes on line in 2019, the complex will provide high-purity paraxylene as feedstock for Hengli’s existing purified terephthalic acid (PTA) plants. In addition to paraxylene, the new complex will also produce gasoline and diesel fuels that meet China 5 clean fuel specifications, as well as jet fuel, base lubrication oils, aromatics, and liquefied petroleum gas (LPG).
