Developed in partnership with Fluitec, Mobil Solvancer is an oil-soluble cleaner designed for gas and steam turbine applications, compressors and hydraulic systems.
Image courtesy of ExxonMobil.
ExxonMobil announcedthe introduction of Mobil Solvancer, a cost-effective, oil-soluble cleaner that aims to help operators of power generation and petrochemical equipment improve equipment reliability and reach extended overhaul-to-overhaul goals. The product was developed with Fluitec, an industry leader in oil enhancement technologies, and is based on the company’s DECON technology.
Designed for gas and steam turbine applications, compressors and hydraulic systems, Mobil Solvancer supports oil conversions, alleviate operational issues due to varnish, and help with oil life extension. The product can be added to in-service oils to help quickly dissolve varnish and organic deposits from within the system, helping address escalating bearing temperatures and avoid issues such as re-adhesion, transfer of deposits, filter fouling, and oil line flow blockage. The cleaner has a low treat rate of 3-5%.
Solvancer is gentle on systems and compatible with a wide range of oils. Specifically, the cleaner is compatible with lubricants and hydraulic oils formulated with API group I to IV base stocks and has no adverse impact on in-service oil or additive performance. Solvancer also offers exceptional seal compatibility, and it is benign to paints and coatings commonly used in gas and steam turbine applications, compressors and hydraulic systems.
For more information, visit: https://info.mobillubricants.com/mobil-solvancer
