Mitsubishi Heavy Industries, Ltd. (MHI) has received an order for a post combustion CO2 capture system, which will capture CO2 from flue gas from an existing coal-fired power generation plant. With a CO2 capture capacity of 4,776 metric tons per day (mtpd), the system is designed for the enhanced oil recovery (EOR) project in Texas, the U.S.A.
Primarily promoted by NRG Energy, Inc., an independent power producer (IPP) of the U.S., and JX Nippon Oil & Gas Exploration Corporation (JX Nippon), a JX Group company of Japan, the system is slated for completion in the fourth quarter of 2016.
MHI received the order from Petra Nova CCS I LLC, a special purpose company (SPC) of NRG and one of the companies implementing the project, through Mitsubishi Heavy Industries America, Inc. (MHIA), a wholly owned subsidiary of MHI in the U.S.A.
Separation and capture of CO2
The EOR project involves the separation and capture of CO2 from flue gas emitted from Unit 8 of NRG's WA Parish generation station, a coal-fired power generation plant, located approximately 60 kilometers southwest of Houston, Texas, and injection of the CO2 into nearby West Ranch oil field to boost crude oil production.
The CO2 capture system is said to consist of a flue-gas quencher, absorber and regeneration system, CO2 compression unit, and utility facilities. It is expected to have a CO2 capture efficiency of 90 percent. CO2 capture efficiency indicates the ratio (percentage) of CO2 recovered from the flue gas by the process against total amount of CO2 contained in the flue gas.
MHI will license CO2 capture technology to Petra Nova CCS I through MHIA. The MHIA/TIC consortium will undertake engineering, procurement and construction (EPC) of the CO2 capture system and its ancillary facilities.
MHI's CO2 capture technology is the KM CDR Process, which uses a proprietary KS-1 TM high-performance solvent for CO2 absorption and desorption that was jointly developed by MHI and the Kansai Electric Power Co., Inc. Compared with other CO2 capture technologies, the KM CDR Process uses significantly less energy. Its outstanding performance is highly regarded, and the process has been adopted in many CO2 capture plants in Japan and abroad.
The consortium partner of MHIA in receiving order from Petra Nova CCS I is TIC - The Industrial Company, a heavy industrial contractor. JX Nippon has participated in the project by purchasing a 50 percent membership interest of Petra Nova Parish Holding LLC, the company that previously owned all the membership interests of Petra Nova CCS I.
Due to various impurities contained in the flue gas, CO2 capture from coal-fired flue gas requires highly sophisticated technology. MHI has conducted small-scale demonstration testing for CO2 capture from coal-fired flue gas at 10 mtpd since 2006, in cooperation with Electric Power Development Co., Ltd. (J-POWER) and completed the verification of uninterrupted table operations.
Recently, the 500 mtpd CO2 capture demonstration test for capturing and sequestering CO2 from emissions at a coal-fired power generation plant, conducted jointly by MHI and Southern Company Services, Inc. (SCS), was completed in December last year, achieving initial phase targets. Based on these results, MHI has been promoting its commercial applications.
